Aim Motorcycle Ecu Bridge With CAN/K-line Communication Cable & Standard OBDII Standard Connector
SKU: B-SM-EB-CK
- מחיר רגיל
- £250.00
- מחיר רגיל
- מחיר מבצע
- £250.00
- מחיר ליחידה
- לְכָל
Product code: X90BRIDGE01
The Aim Motorcycle Ecu Bridge With CAN/K-line Communication Cable & Standard OBDII Standard Connector is available in two variants, the OBDII connector for immediate plug & play connection to the OBDII port of cars with stock ECUs or CAN/RS232 connection for direct installation on aftermarket ECUs.
They are compatible with Aim MXL Dash, Aim G-Dash and of course with the Aim SmartyCam HD and Aim SmartyCam GP HD racing cameras.
ECU Bridge
ECU Bridge and RPM Bridge are two systems that are needed whenever engine data needs to be viewed on a display or on a SmartyCam video (if no recording is require.
ECU Bridge is to be used in when the Engine Control Unit transmits data by either OBDII, CAN or RS232.
ECU Bridge Connection Example
RPM Bridge Connection Example
ECU with Aim Products
ECU Bridge is available in two variants:- With OBDII connector, for immediate plug&play connection to the OBDII port of cars with stock ECUs
- With CAN/RS232 connection, for direct installation on aftermarket ECUs.
RPM Bridge
RPM Bridge is to be used whenever the bike has got no ECU.
Technical Specification
- Configurable ECU interface
- CAN protocol for external modules (visors or SmartyCam HD)
- USB port for PC communication
- External power 8/18 V
- Coil signal 150-400 V
- Square wave signal 4-50 V
In The Box
ECU Bridge
- ECU Bridge with connection cable (CAN/RS232 or CAN/K Line)
- USB cable
ECU
Stock and Racing ECU's
You can find a list of ECU's on our support site here
