דלג לפרטי המוצר
1 שֶׁל 4
8 Button Handlebar Control Switches for Motorcycle
SKU: SP231
מחיר רגיל
£315.00
מחיר רגיל
מחיר מבצע
£315.00
This eight-button custom motorsport configuration switch has been designed for use on race & track bikes, with the standard ECU and where lights and turn signals are not needed.
Custom 8 button switch pad Road/Track
The aluminium assembly has been ergonomically designed for easy use and encompasses eight sealed momentary switches, which are black in colour and metal bezel.
With rugged machine aluminium construction and fully waterproof switches to provide greater crash protection and electrical integrity.
As an example of functions you could have:
Dash Mode UP
Dash Mode DOWN
Select / Cancel
Main beam OFF / ON
Flasher/lap set
Left Turn
Right Turn
Horn
Eight-way button is all black in colour & metal bezel
Common Ground
400mm DR25
All Switches are momentary N/O
Black - Common Ground
Laser engraved 1 > 8
  • 8-way button
  • Width at the centre: 13.5mm
  • Colour: Black
  • Metal Bezel
  • Common Ground
  • 400mm DR25
  • All switches are momentary N/O
  • Black: Common Ground
  • Switch Sealing: IP67
  • Laser Engraved: 1 - 4
  • Wire colours are 1 - Red, 2 - Green, 3 - White (no stripe), 4 - Blue, 5 - Yellow, 6 - Grey, 7 - Orange, 8 - White (+ stripe)
  • SP231 - BD-SW-8B
  • 1 x 8 Button Handlebar Control Switch
Dash Mode UP
Dash Mode DOWN
Select / Cancel
Main beam OFF / ON
Flasher/lap set
Left Turn
Right Turn
Horn
Common Ground
400mm DR25
  • 8-way button
  • Colour: Black
  • Metal Bezel
  • Common Ground
  • 400mm DR25
  • SP231 - BD-SW-8B
