Kart Brake Pressure T-Piece
SKU: S-TP-OTK
- מחיר רגיל
- £70.00
- מחיר רגיל
- מחיר מבצע
- £70.00
- מחיר ליחידה
- לְכָל
The stainless steel brake pressure sensor T Piece is suitable for all OTK karts. The T-Piece is mounted in the brake line to facilitate adding a brake pressure sensor, providing valuable analysis data for the driver to review.
Suitable for all OTK karts | Made from stainless steel |
Suitable for M10 sensor | |
No adaptors are needed, your original brake line will screw onto the end of the T piece once fitted
Very strong and designed to withstand the rigours of karting
Suitable for an M10 x 1.0 sensor
- Brake Pressure T-Piece
- Stainless Steel
- Suitable for OTK Karts
- Compatible with MyChron4 and MyChron5
- Suitable for M10 Sensor
- 1 x Brake Pressure T-Piece
The stainless steel brake pressure sensor T Piece is suitable for all OTK karts. The T-Piece is mounted in the brake line to facilitate adding a brake pressure sensor, providing valuable analysis data for the driver to review.Key Features :
The stainless steel brake pressure sensor T Piece is suitable for all OTK karts. The T-Piece is mounted in the brake line to facilitate adding a brake pressure sensor, providing valuable analysis data for the driver to review.No adaptors are needed, your original brake line will screw onto the end of the T piece once fitted
- Stainless Steel
