AiM Infrared Sensor for Belt Temperature System
SKU: S-IR-SP
- מחיר רגיל
- £155.00
- מחיר רגיל
- מחיר מבצע
- £155.00
- מחיר ליחידה
- לְכָל
Infrared replacement sensor for the belt temperature system.
Direct replacement sensor | Fits infrared belt temperature system |
Threaded section & lock nut for fitting | 719 4 pin binder |
AiM Infrared Sensor
The AiM infrared sensor is a direct replacement for the sensor supplied with the AiM Belt Temperature System.
Ideal for replacing a damaged sensors or it could be used for using the system on multiple vehicles.
The sensor features a threaded section with a lock nut for secure fastening to a bracket.
Direct replacement sensor for the AiM Infrared Belt Temperature System 719 4 pin binder
AiM Infrared Sensor
Infrared replacement sensor for the belt temperature system.Key Features :
AiM Infrared Sensor
The AiM infrared sensor is a direct replacement for the sensor supplied with the AiM Belt Temperature System.Ideal for replacing a damaged sensors or it could be used for using the system on multiple vehicles.
Technical Specifications
AiM Infrared Sensor
