דלג לפרטי המוצר
1 שֶׁל 3
AiM GPS09 Module Open
SKU: GPS-O-CAN
מחיר רגיל
£275.00
מחיר רגיל
מחיר מבצע
£275.00
GPS09c Open Logo
The coveted Aim GPS, now available to everyone.
GPS09c OPEN
CAN CONNECTION | RS232 CONNECTION | AIM CAN CONNECTION
GPS09c Open is a stand-alone device that can stream, in completely configurable messages, all the GPS data at 25 Hz. It is proposed also in the Pro version that features also a 100 Hz 6 axis IMU.
GPS channels available at 25 Hz:
  • Altitude
  • Latitude
  • Logitude
  • Sats number
  • Pos Accuracy
  • Speed Accuracy
  • GPS Lateral acceleration
  • GPS Linear acceleration
  • GPS Heading
  • GPS Yaw Rate
  • GPS Hour
  • GPS min
  • GPS Sec
  • GPS Millisec
  • Year
  • Month
  • Day
  • Week number
  • ITOW
  • Unix Time
IMU data available through CAN connection at 100 Hz (GPS09c Pro Open only):
  • Acceleration X
  • Acceleration Y
  • Acceleration Z
  • Pirch rate
  • Yaw rate
  • Roll rate
GPS09c Open
THREE OUTPUT STREAMS
GPS09c Open is developed to be compatible with all AiM or not AiM systems.
It offers three output streams; for not AiM systems you can configure the protocol for a CAN or RS232.
OPEN RS232
CONNECTION
Freely user configuarable
OPEN CAN
CONNECTION
AIM CAN
CONNECTION
To be connected as expansion
using the AiM CAN network
A dedicated USB cable is available for the configuration,
through the Race Studio 3 software.
racestudio 3 logo
GPS09c open
EASY CONFIGURATION WITH RACE STUDIO 3
CAN connection
AiM Race Studio 3 software offers the possibility to freely configure the CAN messages.
It is possible to set:
  • Baud rate
  • ID
  • DLC (1-8 bytes)
  • Byte order
    (little endian, big endian)
  • Messages frequency
CAN Conncetion
RS232 Connection
GPS09c Open may be configured for transmitting the GPS NMEA message you need through an RS232 stream.
  • Baud rate
  • ID
  • DLC (1-8 bytes)
  • Byte order
CAN Conncetion
Both GPS09c Open and GPS09c Pro Open are proposed in two different mechanical versions. Vehicle with carbon fiber roof or reduced glass surface may limit the GPS signal: the Roof version of AiM GPS09c Open is specifically designed to avoid signal loss.
GPS09c open standard and roof version roof version of the GPS09c open
AiM GPS09 Module
  • Dimenstions: 64.8 x 53.2 x 19.7mm
  • Weight: 60.5g
AiM GPS09 Module
  • GPS09 Module
GPS09c Open Logo The coveted Aim GPS, now available to everyone.
GPS09c OPEN
  • Altitude
  • Latitude
  • Logitude
  • Sats number
  • Pos Accuracy
  • Speed Accuracy
  • GPS Heading
  • GPS Yaw Rate
  • GPS Hour
  • GPS min
  • GPS Sec
  • GPS Millisec
  • Year
  • Month
  • Day
  • Week number
  • ITOW
  • Unix Time
  • Acceleration X
  • Acceleration Y
  • Acceleration Z
  • Pirch rate
  • Yaw rate
  • Roll rate
GPS09c Open
OPEN RS232
CONNECTION
OPEN CAN
CONNECTION
AIM CAN
CONNECTION
racestudio 3 logo
GPS09c open
CAN connection
  • Baud rate
  • ID
  • DLC (1-8 bytes)
  • Byte order
CAN Conncetion
RS232 Connection
  • Baud rate
  • ID
  • DLC (1-8 bytes)
  • Byte order
CAN Conncetion
AiM GPS09 Module
  • Weight: 60.5g
AiM GPS09 Module
  • GPS09 Module
