דלג לפרטי המוצר
1 שֶׁל 3
AiM Exhaust Gas Thermocouple Temperature Sensor M5 with TC Yellow - 712 3 Pin Patch Lead
SKU: S-T-EGT-P-P-712-TC-15-3
מחיר רגיל
£155.00
מחיר רגיל
מחיר מבצע
£155.00
AiM Exhaust Gas Thermocouple Temperature Sensor M5 K Type
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe. This sensor comes with a TC Yellow  - 712 3 pin patch lead 1.5m.
Measure exhaust gas temperature Thermocouple male fitting
Wide temperature range TC Yellow-712 3 pin patch lead
This sensor also comes with a TC Yellow  - 712 3 pin patch lead 1.5m in length.
Temperature range of 0-1000°C
Sensor cable length 25cm
  • Temperature working range: 0-1000°C
  • Cable sensor length: 25cm
  • Cable Type: Compensated
  • Two-pin male thermocouple connection
  • K Type thermocouple
  • TC Yellow to 712 3 pin patch lead 1.5m
  • AiM Exhaust Gas Thermocouple M5 Sensor (EGT)
