דלג לפרטי המוצר
1 שֶׁל 5
AiM EVO4S Downhill Bike Racing Data Logger
SKU: EVO4S-C-GPS-DH
מחיר רגיל
£1,180.00
מחיר רגיל
מחיר מבצע
£1,180.00
The EVO4S is a powerful and flexible data logger, offering a wide range of sources for your data, leaving the pure adrenaline and gravity fuelled excitement up to you.
Many options for ECU connection Includes GPS Module
Built-in accelerometer & gyro sensor CAN output
5 fully configurable analogue channels 2-speed inputs
AiM EVO4S Data Logger
The AiM EVO4S is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4S samples all the information you need for improving your bike and rider performance.
Add mountain bike suspension potentiometers, which are used to measure the displacement between two points. The potentiometer can measure linear displacements like dampers compression or extension and steering rotation measured through rack displacement. The potentiometers are sold separately and available in 200mm and 250mm in rose joint fittings.
Sensors
4GB memory
  • ECU Connection: CAN, RS232, K-Line
  • External Modules Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
  • Analog Inputs: 5 fully configurable, max 1,000 Hz each
  • Digital Inputs: 2-speed inputs, lap signal, coil RPM input
  • Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
  • Internal Memory: 4GB
  • Connectors: 13 Binder connectors
  • Body: Anodized Aluminium
  • LEDs: 1 system staus
  • Dimensions: 130 x 35 x 46.6mm
  • Weight: 330g
  • Waterproof: IP65
    • EVO4S Data Logger
    • Harness of Your Choice
    • Power Cable
    • Download Cable
    • RPM Harness
    • GPS Module
    • Mounting Bracket
      Sensors
      4GB memory
      • Weight: 330g
      • Waterproof: IP65
        • EVO4S Data Logger
        • Power Cable
        • Download Cable
        • RPM Harness
        • GPS Module
        • Mounting Bracket
