דלג לפרטי המוצר
1 שֶׁל 4
AiM ECU Log Racing Datalogger
SKU: ECU-L
מחיר רגיל
£375.00
מחיר רגיל
מחיר מבצע
£375.00
ECU Log
Compact, powerful, reliable
ECU Log is the smallest datalogger to record data from your ECU. Its dimensions are only 61 x 44 x 27mm.
The reduced size of the ECU Log makes it ideal for motorcycle and any underseat compartment installation. The analysis of the performance is a key factor, all recorded data can be managed in Race Studio 3 Analysis with histograms, scatters, diagrams, maps and even videos recorded with a SmartyCam are automatically synchronized to the laps data for a better comparison.
ECU Log
It records data coming from:
  • ECU stream CAN: K-line or RS232 connections
  • Expansions:
    • GPS09c: GPS module
    • ACC 2: Analog inputs
    • LCU-One S: Lambda controller
    • SmartCam 3 series: Motorsport cameras
Then, it features:
  • ECU connection
  • 4 GB internal memory
  • Removable USB Type-C key
  • Waterproof (IP65)
ECU Log
ECU Log
A flexible system
It is simple to create a complete system with the new ECU Log designed by AiM. Different expansions are available to cover most requirements.
ECU Log
ECU Log
ECU Log
  • ECU Connection: CAN, RS232 or K-Line to 1,000+ industry leading ECUs
  • External Modules Connection: GPS09c/GPS09c Pro, ACC2, LCU1, SmartyCam 3 Series
  • External power: 9÷15 V
  • Internal Memory: 4GB + removable USB-C memory card
  • Connectors: 1socket (Binder) 712, 5 pins, 1socket (Binder) 712, 7 pins, 1 USB Type-C
  • Material: PA6 GS30%
  • Dimensions: 61.4 x 44.7x27.2 mm
  • Weight: 100g approx
  • Waterproof: IP65
    • ECU Log
    • Mini USB drive 16gb
    • Either CAN/OBDII or CAN/RS232/EXT. Power 2m cable
    • USB 2.0 A-Type C-Type 2m cable
      ECU Log
      ECU Log
      • Expansions:
      Then, it features:
      • ECU connection
      • Waterproof (IP65)
      ECU Log
      ECU Log
      A flexible system
      ECU Log
      ECU Log
      ECU Log
      • Waterproof: IP65
        • ECU Log
