AiM Brake Pressure Sensor M10 0-160 Bar
SKU: S-P-B-M10-160-X05PSA00160B10-K
- מחיר רגיל
- £190.00
- מחיר רגיל
- מחיר מבצע
- £190.00
- מחיר ליחידה
- לְכָל
AiM M10 0-160 bar pressure sensor suitable for brake pressure reading.
Key Features:
Please Note: MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today. |
Unlock your potential |
- Supply: 8-16 V
- Accuracy: <+/_ 0.5% FS (CLNH - combined non-linearity and hysteresis
- Characterisation: 500mV / 0 bar
- Consumption: 4500 mV / 5 bar
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: M10
Key Features:
Please Note: MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads. |
EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712-719 extension lead to connect these sensors. |
- Supply: 8-16 V
- Sealing: IP66
- Weight: 30g
- Thread: M10
What's In The Box
