דלג לפרטי המוצר
1 שֶׁל 3
AiM ACC 2 Open Analogue CAN Converter
SKU: ACC-Open-2
מחיר רגיל
£250.00
מחיר רגיל
מחיר מבצע
£250.00
logo The compact AiM Analogue CAN Converter
ENHANCE YOUR LOGGER PERFORMANCE ACC Open is the new compact and powerful Analogue CAN Converter that manages up to four channels at 200 Hz each. Now compatible also with the AiM Solo 2 DL.
ACC Open - Analogue CAN Converter Open
  • Analogue channels: 4 fully configurable channels, 24 bit, A/D, 200 Hz each: TC (with dedicated cable), TR, 0÷5 V, 0÷12 V
  • External power:9÷15 V operational 12÷15 V fully operationa
  • Connection: CAN
  • Connectors: 2 Binder 712 fem connectors
  • Material: PA6 30% glass
  • Dimensions: 44.0 x 38.0 x 19.8 mm
  • Weight:50 g
Acc tech sheet
  • Converter
  • CAN cable 100cm
  • 4 channels harness
  • Connection: CAN
  • Weight:50 g
Acc tech sheet
  • Converter
  • CAN cable 100cm
