דלג לפרטי המוצר
1 שֶׁל 4
SKU: H37-V02573010
מחיר רגיל
£375.00
מחיר רגיל
מחיר מבצע
£375.00
The AiM 37 pin Deutsch Harness is the standard harness supplied with our MX Series Dash Loggers.
Suitable for MXS, MXP, MXG, MXL2. MXm Standard harness
 37 pin harness
37 pin Harness for the MX Series
The AiM 37 pins harness is the standard harness that comes with the MX Series Dash Loggers - MXS, MXP, MXG, MXm.
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with one or two thermocouple connectors and will enable you to connect thermocouple sensors.
  • 37 pin Deutsch Harness
 37 pin harness
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
