AiM 22 Pin Connector and Pins MXS, MXP, MXG, MXL2 Female Deutsch Connector
SKU: P-22P-5CN822F00
- מחיר רגיל
- £180.00
- מחיר רגיל
- מחיר מבצע
- £180.00
- מחיר ליחידה
- לְכָל
The AiM 22 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable for MX Series, MXL2 | 22 pins, One plug |
Ideal for replacement or spares | |
The AiM Female Deutsch electrical connector is suitable with the AiM MX Series (MXL2, MXS, MXG, MXP) dashes.
Use as a replacement part or as part of building a wiring loom.
- 22 Pins Female Deutsch Connector
- 22 Pins
- Plastic Pin Installation Tool
- AiM 22 pins connector kit
The AiM 22 pin plug and pins are ideal if you need a replacement or to keep them as spares.Key Features :
The AiM Female Deutsch electrical connector is suitable with the AiM MX Series (MXL2, MXS, MXG, MXP) dashes.Use as a replacement part or as part of building a wiring loom.
- 22 Pins
