1 de 2
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: YAM-1-PP-YAM-1-B
Prix ​​habituel
£125.00
Prix ​​habituel
Prix ​​de vente
£125.00
The AiM Yamaha motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Yamaha cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Yamaha Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Yamaha bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Example data protocols
  • Specifically designed Yamaha Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Yamaha plug & play connection cable.
  • Yamaha plug & play connection cable
  • 1 bracket
  • 1 rubber dowel
  • 1 Allen screw with flay head M6
  • 1 rubber washer
  • 2 Allen screws with flat head M4 x 10
  • 1 bracket
  • 1 rubber dowel
  • 1 rubber washer
