Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Yamaha YZF-R1/R1M & YZF-R6 AiM EVO4S Logger Plug & Play Cable - AimShop.com
    YAM-1-PP-EVO
    Yamaha YZF-R1/R1M & YZF-R6 Aim EVO4S Logger Plug & Play Cable
    En stock, prêt à être expédié
    £70.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £70.00
    The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to the EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Yamaha plug & play cable 7 pin - 712 male binder connection
    Receive data Suitable for EVO4S Data Logger
    Yamaha Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the EVO4S Data Logger.
    Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
    Yamaha YZF-R6 - From 2017
    Example data protocols
    • Below is a pinout drawing for the Yamaha YZF-R1/R1M & YZF-R6 EVO4S Data Logger plug & play connection cable
    • Yamaha YZF-R1/R1M & YZF-R6 EVO4S Data Logger Plug & Play connection cable
    Technical sheet Race Studio 3
