Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Yamaha YZF-R1 2009-2014 AiM Solo 2 DL & EVO4S Data Logger Plug & Play Cable - AimShop.com
    YAM-3-PP
    Yamaha YZF-R1 2009-2014 Aim Solo 2 DL & EVO4S Data Logger Plug & Play Cable
    En stock, prêt à être expédié
    £60.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £60.00
    The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Yamaha plug & play cable 7 pin - 712 male binder connection
    Yamaha Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
    Yamaha YZF-R1 (YEC included) - 2009-2014
    Example data protocols
    • Below is a pinout drawing for the Yamaha Solo 2 DL and EVO4S Data Logger plug & play connection cable
    • Yamaha YZF-R1 Plug & Play connection cable
    Technical sheet Race Studio 3
