1 de 2
Verbatim Pro U3 64GB UHS-3 (U3) SD Card
SKU: SD-64
Prix ​​habituel
£25.00
Prix ​​habituel
Prix ​​de vente
£25.00
The Verbatim Pro memory cards give professional level performance and are a great addition to our AiM SmartyCam 2.1 HD and SmartyCam 2.2 GP HD cameras.
64GB memory  Water & shock resistant
 Class 3 Suitable for AiM SmartyCams
 64GB SD Card
The Verbatim Pro memory card gives a Pro level performance to advanced cameras and HD camcorders.
UHS Speed Class 3 (U3) rating means you can capture 4K ultra HD and Full HD video then transfer quickly to your computer for viewing and editing.
Suitable for 4K ultra HD video capture and compatible with any device with SDHC/SDXC memory card slot.
Read Speed: up to 90MB/Sec*
Write Speed: up to 45MB/Sec*
*SDXC compatible host device required
**UHS-1 compatible device required, actual performance may very depending on host device, interface and usage conditions.
Product Details
UHS Speed Class 3 (U3) for fast file transfer
Water and Shock resistant
Read Speed: up to 90MB/Sec**
Write Speed: up to 45MB/Sec**
Compatible with cameras and SDHC or SDXC supporting host devices.
  • Product Dimensions: 32mm x 24mm x 2.1mm
  • Product Weight: 1.8 grams
  • Pack Dimensions: 90mm x 3mm x 135mm (W x D x H)
  • Pack Weight: 17.7 grams
  • 1 x Verbatim SD Card
 64GB SD Card
Product Details
