Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Remote Blink Keypad Laser Etched Inserts
    KP
    En stock, prêt à être expédié
    £5.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £5.00
    ALL CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL
    We have an extensive range of laser-etched inserts available to suit any function applications required on your keypad.
    Key Features:
    15mm laser-etched inserts Large range available
    Durable & removable Spares
    We offer an extensive range of 15mm laser-etched inserts designed for our Remote Blink Keypad.
    The inserts are 15mm in size and laser etched to a high standard, with a vast range of available icons to choose from to fit the keypads.
    Please select as many inserts as you wish and add them to your shopping basket.
    Please Note: The example shown above is to show how inserts will look in a keypad.
    Customise your Keypad
    With a fully customisable keypad, you can choose the application that's right for you.
    The inserts are also easily substituted without having to take apart the keypad.
    Customise your keypad in many applications such as Lights, Boost, Heating & Fans and Parking. The list is endless.
    Remote Blink Keypad
    We offer a PRO range of CAN keypads available in 4, 6, 8, 10, 12 and 15 variations.
    Our standard keypads are available in 8 and 12 variations.
    • Inserts: Laser Etched
    • Size: 15mm
    • Laser-etched insert
    • The amount depends on what is selected at checkout
