1 de 2
GASGAS Plug & Play AiM Taipan Motocross ECU Kit for Linkpop
SKU: C-ECU-KIT-GG-XE1ECUHBSUCB0
Prix ​​habituel
£635.00
Prix ​​habituel
Prix ​​de vente
£635.00
AiM Taipan ECU Plug & Play Kit For GASGAS Motocross Bikes
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 usec for turning the spark ON!
UC Bridge - Optional Extra
Tuner License :
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections
Below shows a functional diagram of products that can be added to the Taipan ECU:
Traction Control
Launch Control
The UC Bridge is the connection between the CAN bus of the ECCU and the USB port of your PC. It is available in 2 different licenses : User License : A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
Tuner License : With this license, the tuner can create different maps, configurations and strategies designed for the rider's bike. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
AiM Taipan ECU Plug & Play Kit for GASGAS
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for GASGAS
Video
