1 de 2
Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
Prix ​​habituel
£67.00
Prix ​​habituel
Prix ​​de vente
£67.00
Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Panigale plug & play cable 7 pin - 712 male binder connection
Ducati Panigale Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 959 Panigale - From 2016
1199 Panigale - 2012-2014 1199R Panigale - 2015-2017
1299 Panigale - 2015-2019
Example data protocols
  • Below is a pinout drawing for the Ducati Panigale 899, 959, 1199, 1199R, 1299 plug & play connection cable
  • Ducati Panigale 899, 959, 1199, 1199R, 1299 Plug & Play connection cable
