Ducati Hypermotard 796 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
- Prix habituel
- £67.00
- Prix habituel
- Prix de vente
- £67.00
- Prix unitaire
- par
Ducati Hypermotard 796 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Hypermotard plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Ducati Hypermotard Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Hypermotard bike model:
Hypermotard 796 - 2009-2011 |
Example data protocols
- Below is a pinout drawing for the Ducati Hypermotard plug & play connection cable
- Ducati Hypermotard Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati Hypermotard bike model:Hypermotard 796 - 2009-2011 |
