Ducati 848, 1098, 1198 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: DUC-PP-DUC-2-B
- Prix habituel
- £125.00
- Prix habituel
- Prix de vente
- £125.00
- Prix unitaire
- par
The AiM Ducati motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Ducati cable & bracket | 7 pin - 712 male binder connection |
Ducati Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Ducati bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Ducati bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Ducati bike models:
848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
1198 Base/S/S Corse/R Corse/SP - 2009-2011 |
Example data protocols
- Specifically designed Ducati Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the Ducati plug & play connection cable.
- Ducati plug & play connection cable
- 1 bracket
- 2 self-locking nuts
The AiM Ducati motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.The AiM Ducati bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Ducati bike models:848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
- 1 bracket
