Aim Solo 2 DL GPS + ECU Track Day Lap Timer
SKU: SOLO2-K2
- Prix habituel
- £630.00
- Prix habituel
- Prix de vente
- £630.00
- Prix unitaire
- par
The Most Precise & Easy Way To Get Lap Times
Upgrade your track day setup with one of the best motorsport lap timers in the industry — the Solo 2 DL GPS Lap Timer. Equipped with a 25 Hz GPS, ECU connection, built-in gyro, user-friendly interface and compatibility with session performance analysis software, the Solo 2 DL provides precise lap times and detailed telemetry for amateur and professional drivers to optimise their performance and achieve their motorsport goals.
Solo 2 DL Key Features
Why Choose The Track Day Solo 2 DL With ECU Connection
The Track Day Solo 2 Lap Timer includes a high-precision 25Hz GPS and receives data from GPS and GLONASS satellite constellations. This allows the Solo 2 Lap Timer to display instant speed, timing splits, live data and predictive lap times on its high-contrast display with an accuracy of two-hundredths of a second.
Building on the features of the Solo 2 model, the Solo 2 DL connects directly to the vehicle's ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and vehicle ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
The GPS technology provides better reliability from the predictive lap timing function, so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can also build the layout of the display to show the data you want to see.
Advanced Display
The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 8 different backlight colours, which you can select to suit your requirements.
The Solo 2 DL can be connected to the vehicles ECU to obtain various data from the sensors you have fitted to your vehicle. Solo 2 DL manages all the hardware ECU connections and all the communication lines: depending on whether you want to connect to the ECU using the OBDII port or directly to the ECU through the CAN/RS232 channel. If the ECU protocol is not supported connection to the Solo 2 DL to a coil RPM will provide a digital input delivered from square wave signals or pulse signals.
The sampled data you record depends on the actual ECU, typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is constantly updated.
Data Recall On Screen
Solo 2 DL can be used for circuit racing and point to point or regularity events and performance tests such as 0-60mph. And just like the circuit racing mode, all the data is recorded and can be reviewed immediately after each race or test session.
Solo 2 DL Track Database
Solo 2 DL allows you to create a new temporary or permanent track layout. Whether it's a point to point run for rallying or a closed-loop track.
The Aim Solo 2 DL 25Hz GPS lap timer is designed to be easy to use and provides accurate data for analysing your lap times. The device is equipped with a high-precision GPS receiver that can track your position on the track with accuracy. This allows you to see your exact racing line and compare it to optimal lines for faster lap times. A lot of users class this as the best track day lap timer as this also includes accelerometers and gyroscopes to track your car's movements and provide detailed data on acceleration, braking, and cornering forces.
One of the standout features of the Aim Solo 2 DL GPS lap timer is its ability to connect to your car's ECU to gather additional data. This allows you to monitor engine performance, coolant and oil temperatures, and other vital information that can help you fine-tune your driving technique. The lap timer can also display predictive lap times based on your current performance, giving you real-time feedback on how you are tracking against your previous best lap.
Another great advantage of the Aim Solo 2 DL GPS lap timer is its versatility. The device is designed to be compatible with a wide range of vehicles, from production cars to race cars. It can be easily mounted on your dashboard or windshield for easy visibility during your track sessions. The lap timer is also designed to be durable and withstand the rigours of track day racing, so you can focus on improving your lap times without worrying about the device failing.
Overall, the Aim Solo 2 DL GPS lap timer is a great tool for anyone looking to improve their track day performance. With its advanced features, accurate data tracking, and compatibility with a wide range of vehicles, this device can help you take your racing to the next level. Whether you are a beginner looking to shave seconds off your lap times, or a professional racer looking for that extra edge, the Aim Solo 2 DL GPS lap timer is a valuable tool to have in your arsenal.
With over 4,000 tracks pre-loaded from around the world. As soon as it's switched on, the Solo 2 DL identifies its position. If the track is not one of the pre-loaded, Solo 2 will create a new one for you, and once you start to drive, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Wi-Fi Communication With The PC
The Solo 2 DL has integrated Wi-Fi. If you want to review your data in more depth, transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. You can then import the data into the Race Studio 3 software.
Add SmartyCams and a Lambda Control Unit to increase your data performance.
With Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You can also manage the map of all your racing tracks and compare two laps by watching the video recorded by the SmartyCam HD camera.
Race Studio 3 also allows you to download and analyse all data recorded by your Solo 2 DL to your laptop/PC. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
Advanced Display
Aim Solo 2 DL Lap Timer GPS + ECU Racing Dash Logger
- Display: Graphical
- Backlight: 8 configurable RGB colours
- GPS: 25Hz
- External power: 12V
- Connectors: 1 socket (binder) 712, 5 pins, 1 socket (binder) 712, 8 pins
- Memory: 4 GB
- Weight: 240g, battery included
- Solo 2 DL
- Power cable with AC adapter
- User manual
- Aim Sticker
