AiM Solo 2 Dash / Steering Wheel Mount
SKU: UP-SOLO2
- Prix habituel
- £17.00
- Prix habituel
- Prix de vente
- £17.00
- Prix unitaire
- par
The Solo 2 dash/steering wheel mount is an easy and permanent fixture for mounting your Solo 2.
Solo 2 dash/steering wheel mount | 2mm thick stainless steel |
Solo 2 / Solo 2 DL Spare Backing Plate
The Solo 2 dash/steering wheel mount is ideal if you want a permanent and easy fixture.
2mm in raw stainless steel
Other options are available to assist with this product, see the accessories tab for more options.
- Dash/steering wheel mount
- 2mm raw stainless steel
- Solo 2 dash/steering wheel mount
The Solo 2 dash/steering wheel mount is an easy and permanent fixture for mounting your Solo 2.Key Features :
The Solo 2 dash/steering wheel mount is ideal if you want a permanent and easy fixture.2mm in raw stainless steel
