1 de 3
AiM Mychron5 S 2T Patch Lead Double Yellow TC Plugs
SKU: P-712-TC-TC
Prix ​​habituel
£50.00
Prix ​​habituel
Prix ​​de vente
£50.00
The AiM MyChron5 s 2T (2 Temperature) model MyChron4 and MyChron5. These patch leads are used for connecting different temperature sensors to the dash.
Double Yellow TC plugs Suitable for fitting EGT, Underplug sensor
Compatible with MyChron 4 & 5
Connects to the three-pin (712) TEMP port on the Mychron dash.
This AiM Double TC Mignon Plug is suitable for fitting an Exhaust Gas Temperature Sensor (EGT) and an Underplug Temperature Sensor or 2 x Exhaust Gas Temperature (EGT) or 2 x Underplug Temperature Sensors.
Cable length 1.5m
  • MyChron5 S 2T patch lead with double TC plugs
  • Add two water temperature sensors with this patch lead
  • Cable length: 1.5m
  • MyChron5 S 2T Patch Lead Yellow TC Plugs
Cable length 1.5m
