1 de 3
AiM MXm 5" Compact Dash Display
SKU: MXM-X87MXM0000-CAR
Prix ​​habituel
£1,025.00
Prix ​​habituel
Prix ​​de vente
£1,025.00
AiM MXm Compact Dash Display
The Mxm features advanced data logger capabilities.
Key Features:
  • High contrast configurable display
  • Integrated GPS
  • CAN & Analogue Data Input
  • 5 configurable RGB colours
  • 5 configurable RGB LEDs Shift lights
  • 2 configurable RGB LEDs alarms
  • Waterproof
  • Free race studio 3 download
A Wide Range of Data Sources.
The AiM Mxm is a compact unit which features advanced data logging capabilities and is designed for racers needing all the essential information to monitor their vehicle for behaviour and to improve performance.
Designed to acquire and display data coming from the ECU, as well as from the internal GPS receiver, analogue/digital inputs and predefined math channels.
Integrated Shift Light & Alarms
The display has an integrated shift light system which features 5 fully configurable LEDs which can be customised to your requirements and for each gear. Two further RGB alarm LEDs can be configured to operate as warning alarms.
These warning lights can be customised for a particular parameter that requires a warning light, the colour of the LED, and whether you want a solid flashing style alarm, even the flashing frequency can be tailored to suit your requirements.
Sharp Liquid Crystal Display
The Mxm display also offers a great range of customisation. Making use of a sharp liquid crystal screen, you can select the information that is displayed and the backlight can be switched between 7 available colours, all with high contrast and easy-to-read graphics.
The display is kept at an optimum brightness level thanks to an ambient light sensor so that it is always easy to read, no matter what the lighting conditions.
Two Power Outputs
MXm features two power outputs that can drain up to 15 A each.
The two power outputs can be configured on the value of the analogue or digital inputs. They permit to automatically run external systems, such as: switching on/off additional lights, to activate/de-activate a cooling fan or circulation pumps when a certain event happens.
Data Recall On Screen
The information that is displayed on the screen can be fully configured by the user to prioritise the most important information for the driver.
If there is simply too much information to be shown on the screen, the driver can scroll between multiple pages using the integrated buttons so that nothing is missed.
After the session has concluded, all of the data can be recalled on the screen including a summary of the driver's best laps along with max/min RPM, speed and temperatures. If you prefer to go through your data in more detail, the Mxm features a Wi-Fi function to enable and secure data transfer from a laptop to pc up to 50 meters away, so you won't need to take the laptop into the car.
Not Enough
As with all our data logging systems, the Mxm is part of a modular system which allows you to get the most out of the unit. When connected to the optional AiM Data Hub, the Mxm dash can be used in conjunction with the LCU-One Lambda Controller and the range of SmartyCam Cameras.
Compare AiM Dashes
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
AiM Product Video
  • Display Resolution: 268x128 pixels
  • Ambient Light Sensor: Yes
  • Shift lights: 5 configurable RGB LEDs
  • Alarm LEDs: 2 configurable RGB LEDs
  • CAN connections: 2
  • ECU connections: CAN, RS232 or K-Line
  • ECU compatibility: +1000 industry-leading ECUs
  • GPS: Integrated
  • External Modules: Lambda Controller and SmartyCam HD
  • Analogue Inputs: 4 fully configurable, max 1000 Hz each
  • Digital Inputs: 2-speed inputs, coil RPM input
  • Digital Outputs: 2 high-side
  • Wi-Fi Connection: Yes
  • Internal Memory: 4 GB
  • Body: Glass fibre reinforced nylon
  • Pushbuttons: Metallic
  • Connectors: 37 pins motorsport connector + 4 pins power connector
  • Dimensions: 137x88.4x31.9 mm
  • Weight: 330g
  • MXm Compact Dash Display
  • 37 PIn Standard Harness
  • 4 Pin Connector Kit
Key Features:
  • Integrated GPS
  • Waterproof
Two Power Outputs
Not Enough
Compare AiM Dashes
AiM Product Video
Technical Specifications
  • GPS: Integrated
  • Weight: 330g
Whats in The Box
