AiM LCU-One Lambda Controller Replacement Weld on Bung Motorcycle
SKU: LCU-FR-MC
- Prix habituel
- £10.00
- Prix habituel
- Prix de vente
- £10.00
- Prix unitaire
- par
The AiM steel LCU-One Lambda Controller replacement weld-on bung.
Replacement weld-on bung | Steel Bung |
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.
The female-threaded steel connectors feature a natural finish.
The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.
- Weld-on Bung
- 24.7mm (1.5mm)
- x 1 Weld on Bung 24.7mm (1.5mm)
The AiM steel LCU-One Lambda Controller replacement weld-on bung.Key Features :
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.The female-threaded steel connectors feature a natural finish.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.Expand Your System
The above image shows how you can put a system together to increase your data performance.Technical
- Weld-on Bung
- 24.7mm (1.5mm)
