1 de 2
AiM IR Pick Up 719 Plug 90cm Kart
SKU: S-IR-719-9
Prix ​​habituel
£80.00
Prix ​​habituel
Prix ​​de vente
£80.00
AiM IR Optical Lap Receiver 719 Plug
The AiM Infrared Receiver is a spare or replacement Receiver that is installed in your kart and receives the lap signal from the infrared transmitter.
Spare / Repalcement Reciver 4 pin 719 connector
The AiM Infrared Receiver sometimes referred to as an Optical Lap Reciever is installed in your kart and receives lap signals from the infrared transmitter positioned at the side of the track. It just needs to be pointed to the side of the track where the transmitter is installed to be able to read the signal.
It is also available with a 4 pin metal plug connector.
The kart infrared receiver is available with a 90cm lead, it is also available with 300cm lead for cars, although there is nothing stopping you from using the lead that best suits your requirements.
Installation
The Infrared receiver should be fixed to your kart by fixing through the fixing hole at the top of the receiver. When fixing the receiver be sure that the eye is pointing to the side of the track where the receiver has been installed.
Analyse with Race Studio 3
AiM IR Optical Lap Receiver 719 Plug 90cm
  • Binder connection Pinout:
  • 1 - n.c
  • 2 - GND
  • 3 - V battery (7-15 VDC)
  • 4 Optical Lap Signal
  • IR Optical Lap Receiver 719 Plug 90cm
Installation
  • 1 - n.c
  • 2 - GND
