Aim GPS09 Pro Module
SKU: GPS-PRO-1
- Prix habituel
- £420.00
- Prix habituel
- Prix de vente
- £420.00
- Prix unitaire
- par
This Pro verision of GPS09 features a 6 axis 100Hz inertial platform
The GPS Pro Module is connected via a CAN cable which makes it quick and simple to install.
GPS09 Pro Benefits
On the Track
Choice of options
The GPS09 Module is available in 0.5m, 1.3m, 2m or 4m cable and 2m or 4m in a roof version (with cable entry from underneath) specifically designed for easy installation on covered cars.
IMU data available through CAN connection at 100 Hz:
- Acceleration X
- Acceleration Y
- Acceleration Z
- Pirch rate
- Yaw rate
- Roll rate
AiM GPS09 Module
- Weight: 60.5g
- Inertial platform : 100 Hz internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
AiM GPS09 Pro Module
- GPS09 Pro Module
GPS09 Pro Benefits
On the Track
Choice of options
- Acceleration X
- Acceleration Y
- Acceleration Z
- Pirch rate
- Yaw rate
- Roll rate
AiM GPS09 Module
- Weight: 60.5g
- GPS09 Pro Module
