AiM GPS09 Motorcycle GPS Module
SKU: GPS-MC
- Prix habituel
- £265.00
- Prix habituel
- Prix de vente
- £265.00
- Prix unitaire
- par
AiM GPS09 Module
GPS09 Benefits
On the Track
Choice of options
The GPS09 Module is available in 0.5m, 1.3m, 2m or 4m cable and 2m or 4m in a roof version (with cable entry from underneath) specifically designed for easy installation on covered cars.
AiM GPS09 Module
- Weight: 60.5g
AiM GPS09 Module
- GPS09 Module
AiM GPS09 Module
GPS09 Benefits
On the Track
Choice of options
AiM GPS09 Module
- Weight: 60.5g
AiM GPS09 Module
- GPS09 Module
