AiM EVO4S Downhill Bike Racing Data Logger
SKU: EVO4S-C-GPS-DH
- Prix habituel
- £1,180.00
- Prix habituel
- Prix de vente
- £1,180.00
- Prix unitaire
- par
The EVO4S is a powerful and flexible data logger, offering a wide range of sources for your data, leaving the pure adrenaline and gravity fuelled excitement up to you.
Many options for ECU connection | Includes GPS Module |
Built-in accelerometer & gyro sensor | CAN output |
5 fully configurable analogue channels | 2-speed inputs |
AiM EVO4S Data Logger
The AiM EVO4S is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4S samples all the information you need for improving your bike and rider performance.
Add mountain bike suspension potentiometers, which are used to measure the displacement between two points. The potentiometer can measure linear displacements like dampers compression or extension and steering rotation measured through rack displacement. The potentiometers are sold separately and available in 200mm and 250mm in rose joint fittings.
Sensors
4GB memory
- ECU Connection: CAN, RS232, K-Line
- External Modules Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
- Analog Inputs: 5 fully configurable, max 1,000 Hz each
- Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
- Internal Memory: 4GB
- Body: Anodized Aluminium
- LEDs: 1 system staus
- Weight: 330g
- EVO4S Data Logger
- Harness of Your Choice
- Power Cable
- Download Cable
- RPM Harness
- GPS Module
- Mounting Bracket
The EVO4S is a powerful and flexible data logger, offering a wide range of sources for your data, leaving the pure adrenaline and gravity fuelled excitement up to you.Key Features :
The AiM EVO4S is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4S samples all the information you need for improving your bike and rider performance.Add mountain bike suspension potentiometers, which are used to measure the displacement between two points. The potentiometer can measure linear displacements like dampers compression or extension and steering rotation measured through rack displacement. The potentiometers are sold separately and available in 200mm and 250mm in rose joint fittings.
Sensors
5 fully configurable analogue channels with configurable 12-bit o-5 Volt, 0-5000 mV inputs or thermocouple input, used to sample data coming from the temperature, pressure, suspension and other sensors.2-speed inputs which will allow you to monitor different wheel behaviours.
4GB memory
You can add optional expansion modules via the built-in CAN bus.Channel Expansion: Permits to add 4 0-5volt analogue channels for pressure, temperature sensors and potentiometers (suspension, steering angle). Two of these channels can be configured to receive digital inputs like wheel speed.
These are only some of the items that can be added to our EVO4S for incrementing the performance and the data acquired.Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded by EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performance.Technical
- Weight: 330g
- EVO4S Data Logger
- Power Cable
- Download Cable
- RPM Harness
- GPS Module
- Mounting Bracket
