1 de 4
Suzuki GSX-R 1000/750/600 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-SUZ
Precio regular
£710.00
Precio regular
Precio de venta
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Suzuki this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Suzuki ECU connection cable
This kit has been specifically designed for Suzuki bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.
GSX-R600 - 2006-2019 GSX-R750 - 2006-2019
GSX-R1000 - 2005-2022 GSX-R1300 Hayabusa Gen.2 - 2008-2016
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 GSX-R750 - 2001-2019
GSX-R1000 - 2001-2004 and 2009-2019
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
The Suzuki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Suzuki plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Suzuki Connection Cable
  • Bracket
  • 1 Allen screw with a rounded head M8 x 45mm
  • 1 toothed washer
  • 1 rubber dowel
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 1 toothed washer
  • 1 rubber dowel
