1 de 1
Super B Touch Display ( Displays Battery, Voltage, Current & Status )
SKU: TD
Precio regular
£200.00
Precio regular
Precio de venta
£200.00
superb lithium batteries
The Super B touch display is a smart battery meter that can measure and display the voltage, current, state of charge and time to go of your lithium battery. This gives you 24/7 insight in the available capacity of the battery.The touch display is suitable for 12 volt systems of the Nomia and Epsilon and can be set up in 6 different languages: English, French, German, Dutch, Italian and Spanish.
PRODUCT SPECIFICATIONS
Weight
110 gr / 0.24 lbs
Supply voltage range
8 DC to 35 VDC
self-discharge
<3% per month
Supply current
80mA (max) / 6mA (SLEEP mode)
Front display
2,4-inch TFT color screen with 320x240 pixel resolution
Operating temperature
-10°C to 50°C / 14℉ to 122℉
Storage temperature
-20°C to 70°C / -4℉ to 158℉
Fixing
4 screws
Network protocol & connector
CANBus / RJ11
Dimensions
Front Ø 93mm / Body Ø 72mm / Depth 27mm
Available to download Here
superb app
Specifications
Weight
110 gr / 0.24 lbs
8 DC to 35 VDC
self-discharge
<3% per month
Supply current
Front display
Storage temperature
Fixing
4 screws
CANBus / RJ11
Dimensions
Quickstart Guide
Mobile App
superb app
