1 de 2
Super B Epsilon 12V100Ah Lithium Traction Battery
SKU: SB-E-100
Precio regular
£1,215.00
Precio regular
Precio de venta
£1,215.00
superb lithium batteries
The Epsilon 12V100Ah Lithium Iron Phosphate battery has the highest capacity in a standard casing available on the market. The highly sophisticated and integrated BMS brings safety, functionality, and ease of use together in a lightweight and robust casing. The fully automatic heating functionality, improved Bluetooth connectivity, and multi-connectable coated aluminum terminals make this battery a must-have.
  • Product Features
  • A-grade prismatic cells for highest possible energy density and quality
  • Lithium Iron Phosphate (LiFePO4): Safe lithium technology
  • Integrated short circuit protection
  • Integrated protection device for maximum protection and safety
  • Integrated BMS (Battery Management System)
  • Integrated cell heating to allow safe charging below 0°C (with autonomous operation if needed)
  • Adaptive cell balancing
  • Robust casing made from environmentally friendly materials (fully recyclable)
  • Overheating protection on battery terminals in case of badly connected cables
  • Communication interface: Bluetooth (wireless), CAN bus(wired) and LIN bus (wired)
  • Configurable general purpose inputs/outputs to control external devices (chargers for example)
  • Separate power output connection for powering accessories. Analog SoC output
  • Battery monitoring / History Storage
  • Monitoring via Be In Charge Bluetooth app (iOS and Android) and Be In Charge Software (PC)
  • Multi-connectable coated aluminium terminals, including temperature sensors for protection
  • LN3 / DIN H6 and LN5 / DIN H8 sizes available in different capacity (100Ah and 150Ah)
  • Integrated and configurable discharge limit (Shutdown based on State of Charge)
Intended Use
The Epsilon 12V100Ah/12V150Ah Li-ion battery serves as an energy source of 12V in power systems for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications. Potential applications of this Li-ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles. Use as a starter battery is not possible. Never install multiple Epsilon Li-ion batteries in series. Up to 8 batteries can be connected in parallel to increase the total capacity up to 800Ah or 1200Ah depending on the Epsilon variant.
PERFORMANCE
Low maintenance
Fast charging
Safest lithium technology
High discharge currents
High capacity
Low weight
High cycle count
Low self-discharge
EPSILON BLUETOOTH TROUBLESHOOTING
EPSILON AUTOMOTIVE TERMINAL CONNECTORS
CERTIFICATIONS
UN38.3 UN38.3 UN38.3 UN38.3 UN38.3
3 Year Warranty
A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all of our batteries in the harshest environments.
3 year warranty
The Super B Epilson 12v100ah Lithium Traction Battery is an innovative and reliable power source for a wide range of applications, from electric vehicles to industrial equipment. This high-performance battery is designed to provide consistent and long-lasting power, making it the ideal choice for those who rely on their equipment to perform at its best. With its lightweight and compact design, the Super B Epilson 12v100ah Lithium Traction Battery offers a convenient and efficient energy solution that is perfect for a variety of demanding environments.
One of the key benefits of the Super B Epilson 12v100ah Lithium Traction Battery is its impressive cycle life, which far surpasses that of traditional lead-acid batteries. With a cycle life of up to 5000 cycles, this lithium battery offers a reliable and cost-effective power solution that will last for years to come. This extended cycle life not only reduces the need for frequent battery replacements, but also helps to lower overall maintenance costs, making the Super B Epilson 12v100ah Lithium Traction Battery a smart investment for those looking to maximise the efficiency and longevity of their equipment.
In addition to its long cycle life, the Super B Epilson 12v100ah Lithium Traction Battery also boasts a fast charging capability that allows for quick and efficient recharging. With a high charge/discharge rate, this lithium battery can be recharged in a fraction of the time it takes to recharge a traditional lead-acid battery, ensuring that your equipment is always ready to go when you need it most. This faster charging time not only improves the overall efficiency of your operations, but also helps to reduce downtime and increase productivity, making the Super B Epilson 12v100ah Lithium Traction Battery an essential component for businesses that rely on their equipment to keep things running smoothly.
ELECTRICAL SPECIFICATIONS
Nominal capacity
100Ah
Open circuit voltage
13.2v
self-discharge
<3% per month
Cycle Life
>5000 cycles (at 100% DoD)
Voltage
12v
MECHANICAL SPECIFICATIONS
Dimensions (LxWxH)
278 x 175 x 190 mm / 11” x 6.9” x 7.5” (=DIN H6 / LN3)
Weight
10.7 kg / 23.6 lbs
Case material
PC/ABS
Ingress protection
IP56
Cell type / Chemistry
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.3V - 14.6V
Max. charge current
90A
End of discharge voltag
8V
Discharge current continuous
190A
Discharge pulse current
300A
TEMPERATURE SPECIFICATIONS
Charge temperature
-30°C to 45°C / -22°F to 113°F
Discharge temperature
-20°C to 60°C / -4°F to 140°F
Storage temperature
-20°C to 45°C / -4°F to 113°F
COMPLIANCE SPECIFICATIONS
Certifications
CE, FCC, UN 38.3, UN ECE R10.06, UL 1642 (Cells)
Shipping classification
UN 3480
GENERAL SPECIFICATIONS
EAN-13
8718531362208
Battery designation
IFpP/27/148/135[2p4s] M/-20+60/95
Available to download Here
superb app
  • Product Features
Intended Use
PERFORMANCE
Low maintenance
Fast charging
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
3 Year Warranty
3 year warranty
Specifications
Nominal capacity
100Ah
13.2v
self-discharge
<3% per month
Cycle Life
Voltage
12v
Dimensions (LxWxH)
Weight
10.7 kg / 23.6 lbs
Case material
PC/ABS
Ingress protection
IP56
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.3V - 14.6V
Max. charge current
90A
8V
190A
300A
Charge temperature
Storage temperature
Certifications
UN 3480
EAN-13
8718531362208
Battery designation
Quickstart Guide
Mobile App
superb app
