1 de 1
Optimate Charger 5.0A - 14.4V
SKU: OC-5-UK
Precio regular
£118.00
Precio regular
Precio de venta
£118.00
OptiMateTM lithium, the first OptiMate to protect your LiFePO4 battery in a way no other charger did before.
Optimate Charger
The new OptiMate lithium will protect your investment and guarantee your Lithium Iron Phosphate (LiFePO4 / LFP) battery will perform as advertised for a very long time. With 5 Amps of charge current available OptiMate lithium unique multi step ampmaticTM program recharges and balances cells within the battery quickly and efficiently. OptiMate lithium’s maintenance program delivers current to the vehicle circuitry, protecting and keeping the battery at 100% charge. OptiMate lithium – Battery Performance Guaranteed.
PRODUCT SPECIFICATIONS
Dimensions (LxWxH) 199 x 71 x 61mm / 7.8" x 2.8" x 2.4"
Weight 740 gr / 1.63 Ibs
Ingress protection IP54
Operating Temperature -40°C to 40°C / 40°F to 104°F
Programme Control Ampmatic TM microprocessor
Input current max. 0.55A @ 230A
Output current (bulk charge) 0.4A - 5.0A
Reverse drain current Less than 0,001A
Automatic Desulphation Multistage (high voltage, turbo and pulsed mode)
Charge time limit  24 hours (maintenance time: unlimited)
Maintain / test cycles 30 min/30min (alternating hourly)
Charge retention test Range 10.1 - 13.3V GOOD (green) = battery voltage >13.3V
Input-Output cable length 2m
Optimate Charger
Technical Specifications
