Link Mitsubishi VR4Link - VR4X PlugIn ECU
SKU: VR4X
- Precio regular
- £850.00
- Precio regular
- Precio de venta
- £850.00
- Precio unitario
- por
This ECU is designed for the Vr4 4G63T engine.
Includes onboard 4 bar or 7 bar MAP sensor.
Knock control not available on this ECU.
Suitable Applications:
Mitsubishi Galant VR-4 E38A (1987-1992) with 4G63T engine
Mitsubishi Galant VR-4 E39A (1987-1992) with 4G63T engine
1G DSM with 4G63T engine
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI 6 Digital Input for switching functions.
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
Expansion connector 2
Aux 9 EThrottle - can't be used as an Aux out
Aux 10 Auxiliary Output
An Volt 7 Analog 0-5V input
An Volt 9 Analog 0-5V input
An Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
Mitsubishi Galant VR-4 E38A (1987-1992) with 4G63T engineMitsubishi Galant VR-4 E39A (1987-1992) with 4G63T engine
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
- G4X PlugIn ECU
- Stickers
