Link Knock Sensor (KNS)
SKU: KNS
- Precio regular
- £80.00
- Precio regular
- Precio de venta
- £80.00
- Precio unitario
- por
+ IVA (Solo Reino Unido)
“Knocking” occurs when the air-fuel mixture self-ignites prematurely. Sustained knocking causes damage primarily to the cylinder head gasket and cylinder head. The knock sensor identifies the high-frequency engine vibrations characteristic of knocking and transmits a signal to the ECU. The aim is to obtain the maximum energy yield by starting ignition as early as possible. Engines with a knock sensor can reduce fuel consumption and increase torque.
Donut style
8mm hole
Includes plug and pin kit
- Knock Sensor
- Plug and Pin Kit
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Link_Banner_Description.png?v=1616071775)
“Knocking” occurs when the air-fuel mixture self-ignites prematurely. Sustained knocking causes damage primarily to the cylinder head gasket and cylinder head. The knock sensor identifies the high-frequency engine vibrations characteristic of knocking and transmits a signal to the ECU. The aim is to obtain the maximum energy yield by starting ignition as early as possible. Engines with a knock sensor can reduce fuel consumption and increase torque.Donut style
8mm hole
- Knock Sensor
- Plug and Pin Kit
![Link Knock Sensor (KNS) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkKnockSensor_KNS_1445x.png?v=1618220309)
![Link Knock Sensor (KNS) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkKnockSensor_KNS_2_1445x.png?v=1618220310)
![Link Knock Sensor (KNS) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkKnockSensor_KNS_3_1445x.png?v=1618220312)
