Grey 35 Pin AMP PDM Plug Connector Housing Socket
SKU: P-AMP-35-G
- Precio regular
- £15.00
- Precio regular
- Precio de venta
- £15.00
- Precio unitario
- por
The 35 pin AMP plug is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating.
35 pin AMP connector | Rugged & highly reliable |
The 35 pin AMP plug is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating. The connector has a 2-piece contact hold design with secondary locking to prevent the contact from getting tore out under harsh conditions. These connectors accept a wire size of 0.5 to 1.25mm².
Features and Benefits:
• Rugged and highly reliable design
• IP67 rating to protect against the harshest of conditions
• Housed in a strong plastic
• 2-piece contact hold
• Integrated latch for mating
• Operating temperatures of -40°C to +125°C
- Number of contacts: 35
- Type: Automotive connector housing
- Gender: Male
- Number of rows: 3
- Current Rating: 17A
- Mounting Type: Cable Mount
- Colour: Black
- Termination Method: Crimp
- Height: 34.6mm
- Width: 63.4mm
- Depth: 33.6mm
- Minimum Operating Temperature: -40°C
- Maximum Operating Temperature: +125°C
- Housing Material: PBT
- Waterproof: IP6K9K
- 1 x 35 Pin AMP Plug Connector
The 35 pin AMP plug is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating.Key Features :
The 35 pin AMP plug is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating. The connector has a 2-piece contact hold design with secondary locking to prevent the contact from getting tore out under harsh conditions. These connectors accept a wire size of 0.5 to 1.25mm².Features and Benefits:
• Rugged and highly reliable design• IP67 rating to protect against the harshest of conditions
- Gender: Male
- Number of rows: 3
- Colour: Black
- Height: 34.6mm
- Width: 63.4mm
- Depth: 33.6mm
