1 de 3
AiM Water/Oil Temperature Sensor PT100 M10 Thermo Resistor Motocross
SKU: S-T-M10
Precio regular
£70.00
Precio regular
Precio de venta
£70.00
"Patch Lead Type" is required
"Patch Lead Length" is required
AiM Water/Oil Temperature Sensor M10 Thermo Resistor
The AiM PT100 M10 Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature 4 pins 719 male binder
PT100 - M10
Sensor cable length 25cm
PT100 - M10
  • Temperature working range: 0/150°C
  • Cable sensor length: 250mm
  • M10 Thermo resistor
  • 4 pins male 719 Binder connection
  • 2kΩ 1% resistor between pins 1 and 4
  • AiM Water/Oil Temperature Sensor M10 Thermo Resistor
