AiM Taipan UC Bridge Tuner
SKU: C-UCB-T
- Precio regular
- £520.00
- Precio regular
- Precio de venta
- £520.00
- Precio unitario
- por
The AiM Taipan UC Bridge Tuner is the connection between the CAN bus of the ECU and the USB port of your PC. This UC Bridge Tuner has been specifically designed to programme and configure an unprogrammed Taipan ECU.
Tuner licence | Basic maps |
Tuner License
If you purchase an unprogrammed Taipan ECU you will need this tuner to configure it. The Taipan ECU will able to be configured to any brand/model of bike
With this license, the tuner can create maps, configurations and strategies designed for the rider's bike. The tuner can flash then directly on the ECU or send an e-mail to allow the rider to download and install them in the ECU.
Taipan ECU Connections - Optional Extra
AiM Taipan UC Bridge Tuner Technical Specifications and pinout
- Connectors: n. 1 USB connection for PC
- n. 1 JST 04R-JWPF-VSLE-S waterproof Connector for CAN Bus communication
- Body: PA6 + 30% glass fiber
- Dimensions: 103.5 x 45.3 x 18.1mm
- Weight: 80g
- 1 x Taipan UC Bridge Tuner
Taipan Video
The AiM Taipan UC Bridge Tuner is the connection between the CAN bus of the ECU and the USB port of your PC. This UC Bridge Tuner has been specifically designed to programme and configure an unprogrammed Taipan ECU.Key Features :
Tuner License
This UC Bridge Tuner has been specifically designed to programme and configure an unprogrammed Taipan ECU.If you purchase an unprogrammed Taipan ECU you will need this tuner to configure it. The Taipan ECU will able to be configured to any brand/model of bike
- Weight: 80g
Taipan Video
