1 de 2
AiM Solo & Solo 2 & Solo 2 DL Motorcycle U Bolt Mount
SKU: SOLO-UB
Precio regular
£67.00
Precio regular
Precio de venta
£67.00
AiM Solo, Solo 2, Solo 2 DL U Bolt Mount
The AiM U Bolt mount is suitable for a 0.5 to 1.2" bar, roll cage or railing. Used to secure for Solo GPS lap timer to your car.
Secure mounting for GPS lap timer Ball & socket for positioning
Suitable for Solo, Solo 2 & Solo 2 DL 0.5 to 1.2" bar
U Bolt Mount for GPS Lap Timer
The AiM U Bolt mount is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
It is used to mount the Solo, Solo 2 or Solo 2 DL to a roll bar, railing or tube. The U Bolt has a unique ball and socket system that provides a solid mounting and is designed to cope with all Motorsport environments.
There are two U shaped junctions in the kit which are 2.5cm and 3cm, so the mount can be mounted to different sized bars.
  • 90mm (3.54inches) arm
  • Clamp base with ball 2.5cm and 3cm in diameter
  • U shaped junctions
  • Locknut
  • Screws and washers
  • 1 U Bolt Mount Bracket for Solo, Solo 2 , Solo 2 DL
  • Locknut
