AiM Solo, Solo 2 & Solo 2 DL Motorcycle Suction Cup Mount
SKU: SOLO-WM
- Precio regular
- £67.00
- Precio regular
- Precio de venta
- £67.00
- Precio unitario
- por
AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount
The AiM suction cup mount is suitable to fit the windscreen or a flat surface. Used to secure for Solo GPS lap timer to your bike.
Secure mounting for GPS lap timer | Ball & socket for positioning |
Suitable for Solo, Solo 2 & Solo 2 DL | |
Suction Cup Mount for GPS Lap Timer
The AiM suction cup mount to suit the Solo, Solo 2 and Solo 2 DL has been designed to securely mount the Solo GPS lap timer to any flat surface such as your windscreen.
It has a 90mm locking and quick release suction cup, also a dual swivel joint making viewing angle adjustment quick and easy.
- 90mm arm
- Suction cup
- Clamp base with ball
- Locknut
- Screws and washers
- 1 suction cup Mount Bracket for Solo, Solo 2, Solo 2 DL
The AiM suction cup mount is suitable to fit the windscreen or a flat surface. Used to secure for Solo GPS lap timer to your bike.Key Features :
The AiM suction cup mount to suit the Solo, Solo 2 and Solo 2 DL has been designed to securely mount the Solo GPS lap timer to any flat surface such as your windscreen.It has a 90mm locking and quick release suction cup, also a dual swivel joint making viewing angle adjustment quick and easy.
- 90mm arm
- Suction cup
- Locknut
