AiM Solo 2 / Solo 2 DL 5 Pin 2M External Motocross Power Lead Unterminated
SKU: SOLO2-EXP
- Precio regular
- £54.00
- Precio regular
- Precio de venta
- £54.00
- Precio unitario
- por
The AiM external power lead fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
5 pin - 712 male binder connection | Unterminated end with 2 wires |
Suitable for Solo 2 & Solo 2 DL | |
External Power Cable
The AiM external power cable fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers. It features a 5-pin 712 male binder connection, which goes into the Solo2/Solo 2 DL.
The un-terminated wires allow you to connect to an external battery.
This allows Solo 2 and Solo 2 DL GPS Lap Timers to have longer running times.
- 5 pin - 712 male binder connection
- Unterminated end with 2 wires: 12V+ & Ground
- 2m length cable
- Solo 2 / Solo 2 DL External Power Lead
The AiM external power lead fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The AiM external power cable fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers. It features a 5-pin 712 male binder connection, which goes into the Solo2/Solo 2 DL.The un-terminated wires allow you to connect to an external battery.
- 2m length cable
