AiM PDM32 With GPS Sensor, Data Logging without Display Screen
SKU: PDM-32-05-XC1PDM3201G050
- Precio regular
- £1,680.00
- Precio regular
- Precio de venta
- £1,680.00
- Precio unitario
- por
AiM Power Distribution Module with GPS08
The AiM PDM32 Power Distribution Module has been designed to easily replace the traditional fuse and relay systems.
Key Features:
AiM PDM32
The AiM PDM32 is a 32-channel advanced power distribution module designed to power a multitude of vehicle circuits removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions. The PDM32 is available on its own or with a choice of 6"" or 10"" dash displays. It is also capable of receiving data from the vehicle's ECU and even includes a data logger and GPS module for lap timing and track mapping. Simplifies electronic installations with greater control |
PDM32 Power Outputs |
The PDM32 features 8 x 15A continuous outputs with a total continuous max current of 120A. Each of the outputs provides feedback to the data logger to provide vital information such as open circuits, high/low voltage, the number of fault retires and the time between the reties is user definable. All outputs can be configured as PWMs for a soft start/stop. All of the PDM circuits can be set up and monitored via our Race Studio 3 Software. |
PDM32 Inputs |
The PDM32 features 8 x analogue/digital inputs, 4 x digital only inputs 2 x speed inputs. |
PDM32 Data Management |
The PDM32 is capable of receiving and recording data from the following sources: ECU - Over 1000 protocols available / Digital / Analogue Inputs / Internal 9 axis EMU / GPS - Lap time and position / Expansions / Push Buttons - From RIO02 module or OUR CAN Keypads / PDM outputs - Currents and status of each channel individually / Other user defined math channels. |
GPS08 Included |
The GPS module option provides easy lap timing and lap position for track mapping. The PDM has over 4000 race tracks in the database so once you arrive at the track the system already knows the timing points so you can just get on with your driving. The GPS module is available in various lead lengths to suit differing applications ECU - Over 1000 protocols available / Digital / Analogue Inputs / Internal 9 axis EMU / GPS - Lap time and position / Expansions / Push Buttons - From RIO02 module or OUR CAN Keypads / PDM outputs - Currents and status of each channel individually / Other user defined math channels. |
Dash Display OptionSuitable for replacing all of the dashboard gauges and warning lamps these TFT dash displays are available in 6"" or 10"" versions. Both are fully configurable displays and offer a range of layouts. |
AiM PDM32
- Inputs: 14 fully configurable, max 500Hz each: 8 analogue/digital 4 digital inputs of which 2 speed input
- Power Outputs: 4 rated up to 20 A (high power) 12 rated up to 15 A (mild power) 12 rated 10 A (low power) 4 rated up to 35 A (half bridge) Protected for: over voltage, under voltage, over current, over temperature. Total max current: 120A
- Lin Bus: 1
- CAN Connections: 3
- Intertial Platform: 3 axis + 5G accelerometer + axis gyro + 3 axis magnetometer
- Internal Memory: 4 GB
- External Modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module
- External Analogue Camera Input: 2
- Body: Anodised Aluminium
- Dimensions: 161 x 1000.6 x 50.6mm
GPS08 Module
- Weight: 60.5
GPS08 Module Roof Version
- Dimensions: 64.8 x 56.8 x 21.4mm
- Weight: 100g
AiM 10"" TFT PDM Display Screen
Key Features:
AiM PDM32
The AiM PDM32 is a 32-channel advanced power distribution module designed to power a multitude of vehicle circuits removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions. The PDM32 is available on its own or with a choice of 6"" or 10"" dash displays. It is also capable of receiving data from the vehicle's ECU and even includes a data logger and GPS module for lap timing and track mapping. Simplifies electronic installations with greater control 32 outputs, ideal for controlling vehicle electrical circuits Dash controller with 6"" or 10"" dash display options x2 camera outputs GPS Module option for lap timing and track mapping Rugged aluminium case designed to withstand harsh environments Built-in data logging facility to log all PDM outputs and ECU data plus lap timing. |
PDM32 Inputs |
GPS08 Included |
Technical Specifications
AiM PDM32
- Lin Bus: 1
GPS08 Module
- Weight: 60.5
- Weight: 100g
Whats in The Box
