AiM Oil / Fuel Pressure Sensor Dash 3 3/8 24 0-10 Bar
SKU: S-P-O-D3
- Precio regular
- £190.00
- Precio regular
- Precio de venta
- £190.00
- Precio unitario
- por
The AiM 3/8 24 0-10 Bar pressure sensor is suitable for oil and fuel pressure readings and able to read pressures up to 10 bars.
3/8 24 0-10 Bar | 4 pins 719 male binder |
The 3/8 24 0-10 Bar pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Many things affect the various engine pressures, and knowing that your engine has the correct amount is paramount to longevity and performance. Suitable for oil, fuel and water pressure readings.
- Supply: 8-16V
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: 3/8 24
- AiM Oil/Fuel pressure sensor Dash 3 3/8 24 0-10 Bar
The AiM 3/8 24 0-10 Bar pressure sensor is suitable for oil and fuel pressure readings and able to read pressures up to 10 bars.Key Features :
The 3/8 24 0-10 Bar pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Many things affect the various engine pressures, and knowing that your engine has the correct amount is paramount to longevity and performance. Suitable for oil, fuel and water pressure readings.Available with an M10, 1/8 NPT or 3/8 thread and 0-5 or 0-10 Bar pressure range (if higher than 10 Bar is needed, please use the Brake Pressure Sensor).
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: 3/8 24
