AiM MyChron5 S 2T Patch Lead Double TR 719 Plug
SKU: P-712-TR-TR
- Precio regular
- £50.00
- Precio regular
- Precio de venta
- £50.00
- Precio unitario
- por
The AiM MyChron 5 S 2T patch lead with double TR 719 connectors.
Double TR 710 plugs | Suitable for fitting 2 x water temp sensors |
Compatible with MyChron 4 & 5 |
The AiM MyChron5 S 2T patch lead with double TR 719 connector plugs will enable you to attach two water temperature sensors.
Cable length 1.5m
- MyChron5 S 2T patch lead with double TR 719 plugs
- Add two water temperature sensors with this patch lead
- MyChron5 S 2T Patch Lead Double TR 719 Connector
The AiM MyChron 5 S 2T patch lead with double TR 719 connectors.Key Features :
The AiM MyChron5 S 2T patch lead with double TR 719 connector plugs will enable you to attach two water temperature sensors.Cable length 1.5m
