1 de 2
AiM Motocross GET GP1 & GET Power ECU Solo 2 DL Plug & Play Lead
SKU: GET-MX-PP
Precio regular
£67.00
Precio regular
Precio de venta
£67.00
AiM Motocross GET GP1 & GET Power Solo 2 DL Plug & Play Lead
The AiM ECU plug & play cable has been specifically designed for 4 stroke dirt bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
GET plug & play cable 7 pin - 712 male binder connection
GET Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for 4 stroke dirt bike. This plug & play cable can be used for the Solo 2 DL.
Supported models are:
GET GP1 with EVO protocol GET GP1 with A4 protocol
GET Power
Example data protocols
  • Below is a pinout drawing for the GET GP1 / GET Power Solo 2 DL plug & play connection cable
  • GET GP1 / GET Power plug & play Cable
GET Power
