OTK Sensor Holder For Throttle Position Sensor
SKU: B-OTK-T-SB
- Precio regular
- £25.00
- Precio regular
- Precio de venta
- £25.00
- Precio unitario
- por
This holder is specific for the sensor used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.
Suits AiM throttle position sensor kit | Suitable for OTK karts |
Fits to the throttle cable | |
This holder is specific for the sensor used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the sensor to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the magnet is available to purchase separately.
This holder is specific for the sensor used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.Key Features :
This holder is specific for the sensor used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the sensor to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the magnet is available to purchase separately. ![]() |
- Suitable for OTK Karts
- Compatible with MyChron4 and MyChron5
- 1 x OTK Sensor Holder For Throttle Position Sensor
