1 de 3
AiM GPS09 Module For SmartyCam 2.2
SKU: GPS
Precio regular
£265.00
Precio regular
Precio de venta
£265.00
AiM GPS09 Module
GPS09 Benefits
On the Track
Choice of options
The GPS09 Module is available in 0.5m, 1.3m, 2m or 4m cable and 2m or 4m in a roof version (with cable entry from underneath) specifically designed for easy installation on covered cars.
AiM GPS09 Module
  • Dimenstions: 64.8 x 53.2 x 19.7mm
  • Weight: 60.5g
gps09 pinout
AiM GPS09 Module
  • GPS09 Module
AiM GPS09 Module
GPS09 Benefits
On the Track
Choice of options
AiM GPS09 Module
  • Weight: 60.5g
gps09 pinout
AiM GPS09 Module
  • GPS09 Module
