1 de 3
AiM EVO5 Motorcycle 37 Pin Deutsch Harness
SKU: EVO5-H37
Precio regular
£375.00
Precio regular
Precio de venta
£375.00
AiM EVO5 37 Pin Deutsch Harness
The AiM EVO5 37 pin Deutsch harness is the standard harness that is supplied with the EVO5 Data Logger.
Suitable for EVO5 Standard 37 harness
 4 analogue channels
 37 pin Harness for EVO5
The AiM 90° 37 pin Deutsch harness for the EVO5 is the standard harness that is supplied with the EVO5.
This harness can be used to replace a damaged harness or for a second vehicle installation when sharing to moving a dash logger.
The standard 37 pin harness that comes with the EVO5 allows 4 inputs. If you would like to add more inputs to your race data then add this optional harness.
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
  • None ended cables - See table in Downloads Tab
  • EVO5 37 Pin Deutsch Harness
 4 analogue channels
