AiM ACC 3 Open Analogue CAN Converter
SKU: ACC-Open-2
- Precio regular
- £250.00
- Precio regular
- Precio de venta
- £250.00
- Precio unitario
- por
Please note - OPEN devices must be programmed in Race Studio 3 via USB to enable them to transmit data on none preset CAN ID's
ConfigurationWith Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
ACC 3 - Analogue CAN Converter
- Analogue channels: 4 fully configurable channels, 24 bit, A/D, 200 Hz each: TC (with dedicated cable), TR, 0÷5 V, 0÷12 V
- Speed Inputs: 2 (AN3-AN4), max frequency 10 kHz, internal pull-up for open drain/collector input
- External power:9÷15 V operational 12÷15 V fully operationa
- Connection: CAN
- Connectors: 2 Binder 712 fem connectors
- Material: PA6 30% glass
- Dimensions: 44.0 x 38.0 x 19.8 mm
- Weight:50 g
ACC3 Analogue CAN Converter
- ACC3 Converter
- CAN cable
- 4 channels harness
